If I can put way over 800 thru a stock geared small in/out Ford Toploader, a TKX is probably good for at least 1000. Just keep in mind that it's clutch engagement rate that actually decides how much impact abuse the transmission will actually see. Install too much clutch, it will draw inertia out of the rotating assy too quickly, which will either bog the engine, spin the tires, or break something in the drivetrain. All those things make your car slower, so avoid installing more clutch than required to handle the power that you are making.
Clutch engagement rate is just as important to a stick car as proper torque converter stall is to an automatic. Too much clutch will pull the engine down out of it's optimum operating range, just like installing too much converter. Put nitrous on an automatic car, it will require a tighter converter. Run that nitrous converter without nitrous, it will take forever for the engine to get up into it's power range. Adding a 125 shot on top of 650 is going to require a clutch that can handle around 800ftlbs. A car/clutch set up to handle 800ftlb on nitrous is going to bog a 650ftlb engine without nitrous.
On an automatic car, some loosen up an otherwise too tight converter by dumping some converter charge pressure during launch. That basically causes the converter to cavitate, which in-turn temporarily reduces torque multiplication and raises it's stall speed. Bottom line is the engine gets to it's happy place quicker. On a clutch car, you can temporarily hold back some clutch clamp pressure with a clutch hit controller for much the same effect, keeps the engine from getting pulled down out of it's happy place by too much clutch.
All this is a long round about way of saying it's your clutch that will ultimately decide if a TKX lives or dies. Too much clutch will kill it, too much clutch will also make the car slower. Lots of guys go overkill on the clutch, those are the same guys bogging, spinning, and breaking stuff. Adding nitrous is going to require more clutch than optimum for NA launches, but adding an external clutch hit controller is an easy way to dial back that nitrous capable clutch to also work for NA launches.
Personally I would not hesitate to choose the TKX at your power level. High rpm synchro'd shifts, overdrive, in a package that fits? In my book that makes it ideal for a street/strip car.
Grant
