I need a new air filter housing for my 350 and it has a Rochester Quadrajet. Are the housings between a 2bbl and 4bbl interchangeable? The type I need is the factory ThermaVac type.
Also, does anyone know if the fenders of a 4 door work on a El Camino? Thanks.
The air cleaner lid will fit a two or four barrel carb, but the two barrel housing won't..the center hole is too small.
Assuming you are looking for front fenders for a 70-72 ElCamino, the four door fenders will not fit. Sorry! ElCaminos and station wagons use the same fenders and are different from the other stuff.
69 SS396 69 Malibu Ragtop
70 Monte 72 El Camino
Team Chevelle Gold #33
ACES Member #02913
Chevelle Club of Michigan
Rode shotgun in the ONLY Z16 convertible made.
Correct the air cleaner housings do not interchange,you should be able to pick one up at the parts yard for about $5.While your at it get 2 and make a dual snorkle air cleaner
