1 - 10 of 10 Posts
just went to put the plugs in on my afr 305 bbc chevy heads and its a no go. Is there a weird thread on these heads, as far as i knew any bbc, sbc, etc. spark plug would atleast thread in.
camaropwr,
I had no trouble with my 315 cnc heads. AFAIK, they use .750" reach, 5/8" hex head gasketed plugs, along with a little anti-sieze on the threads. Do all the cylinders have this problem?
John
i originally tried the ngk v power 7 out of my old heads. it looks like the threads in the heads are messud up. all the threads looked good, so i never figured it would be a problem. heads are on the motor right now, i might try to chase one of them and see how hard or easily the chaser goes down.
In Memoriam
pack the flutes of the chaser with grease, it will help pick up the shavings.
Are these heads new?
yes there are new, i ran the chaser down all the holes(with grease), and it looks like i caught all the alluminum. i opened the exhaust valve on each cylinder and blew air into the cylinder and out the spark plug hole. it looks like they had a bad tap or atleast a bug on it, when they tapped these. anyways, the chaser cleaned the heads up, so it looks like i avoided a small tragedy. im guessin that if a little chip of aluminum made it into the cylinder, it probably wouldn't hurt anytning being softer than the rings and cylinder wall? lesson here, definatley run a spark plug down each hole before bolting them on.
Crank the engine over about a dozen times with ALL the plugs out before you continue. Aluminum chips will blow out the holes. You leave out the 8 plugs to stop chips from blowing into the intake and other cylinders and becoming trapped.
Harry P Hunter
i feel your pain-years ago i learned to test fit plugs in heads, esp. alumn. b4 install-i had to pull the headers to fix the one i had trouble with
1 - 10 of 10 Posts
