Driving at hiway speed I turned the AC to max (the AC isn't hooked up BTW belt is off) so the only thing it does is shut off the coolant to the heater. About a mile after I did this the temp was closing in on 210 turned the AC off & the temp went back to 185.
Tried it again to make sure it wasn't a fluke mile later temp went back up & then started to cycle up & down.
Is there another problem hiding? Normally runs 185- 190, stock pump 2 row Northern alum rad., stock clutch fan.
