I need the a good set of header gaskets, not collector gaskets. I want a quality set, so what brand will suffice? thanks
Yep, I've used those before with good luck. Those are Percy's. I like the looks of these too. I bought a set of these which I'll be using on my Lemons headers when get them. These are unlike any other header geaskets I've ever seen. BTW, te company recommends that you do NOT torque down the bolts real hard with these gaskets. Tey're very flexible and soft, and don't need the header bolts to be super tight, nor will they need to be re-torqued after the first few heat cycles as with other header gaskets......I'm using those perforated metallic exhaust manifold gaskets, work great, don't stick![]()
Soaking them in water overnight and installing them wet & re torquing helps the 'white cheapies' tooI love the cheapy white gaskets. Never had a leak, and they come off easily when needed.
The key with the cheapy gaskets and others is to keep retorquing them until they take a final set. This may mean tightening them up 5x. Gaskets shrink like bacon once heat and pressure are applied.
+1 on the copper ones for the headers. Never had a leak since I installed them 2 years ago.I use the copper ones for head to header and collector work good and you can re use them.
X2 . havent leaked yet!I like the Remflex's - http://catalog.remflex.com/
I'm with Vince. I have tried quite a few different ones but like the cheap white ones best. Just keep tightening them for the first few heat cylces. I had the last set on for 2 or 3 seasons of racing. Don't know how long they would last with street driving but the best thing about them is if you need to change them they release nice and clean with no lamination mess left on the head or header. I tried some dead soft Summit brand copper gaskets on the collectors this time when I put everything back together. So far so good with them. Sealed up great. May try them eventually on the headers if I need some. The copper releases clean as well.I love the cheapy white gaskets. Never had a leak, and they come off easily when needed.
They're very soft and are made out of graphite. Very different than any other I've seen or had. Aside from that, the claim of the manufacture that grabs my attention is that there's no re-torqueing required with these gaskets. BBC headers can make it challenging to get at some of the bolts. Not that is can't be done, but just something extra that would be nice not having to deal with.I agree 100%....Remflex by far is the best in my opinion. They're thick, but yet conform to the shape of head/header. Check em' out.
