I have a concern that I needs some direction on. I recently rebuilt a mild 350. While breaking in the cam After about 20 minutes of running, the engine suddenly overheated. Warped Edelbrock heads (ouch!) and blown head gasket(s). It appeared that the thermostat was the culprit although it seems odd that it would run that long before overheating. I had the heads cut until flat (.015) and put it back together with a 160 thermostat. The oil and filter didn't show any signs of metal upon visual inspection. The engine now never overheats but seems to blow white smoke out the exhaust at idle and has a somewhat rough idle despite the mild cam (.446/.446, 220 @ .050, 110 LSA). Coolant doesn't appear to be going down and there is no coolant in the oil.
I installed a FAST EZ EFI system and it keeps throwing O2 sensor codes. The techs at work said that antifreeze is the death of O2 sensors so I suspect that the excess moisture blowing out the exhaust (doesn't smell like coolant) might mean coolant leak into the cylinders causing the rough idle and throwing the error codes.
When the engine overheated I did not pull the block and wonder if It may have cracked or if the deck may have some how warped and I still have a leak.
Any ideas before I start turning wrenches?
