Ok all you dash modifiiers out there. I like the look of the white face guages but I want to take this a step further if I can.
I am wondering if any of the guage manufacturers make a "dual guage" like some of the newer cars have. By dual I mean 2 different functions like say oil pressure and water temp or oil pressure and fuel in one instrument.
My thought is I want to add one extra guage to the stock GM SS dash layout and retain everything else that is in the dash.
I want to get all the following instruments:
Large Diameter
tach
Speedo
Small diameter
clock
oil pressure
fuel
Volt or ammeter (eather one)
water temp
Problem is there are not enough holes in the stock dash layout and I won't cut another hole. What I am thinking is if someopne makes a combo of almost any two of the small dia guages in one unit I am home free. Likely the clock would have to be small and by itself just due to the need for a 360 degree face. That gets me to a combo of two of the following fuel, volts / ammeter oil pressure or water temp combined in one guage. Likely that would need to be a little smaller dia than the tach and the speedo but larger in dia than the smaller single function guages.
Any ideas as to a manufacturer to look at????
