1 - 2 of 2 Posts
Figured this will be a lob to most of you here.
'69, BB. New wiring harness (old wires had TWO cobbled on red wires going to starter), with long period between "out and back in" on motor. Want to make sure I put right wire on right terminal before doing anything smokey.
Which color wire (again, new harness) goes to which terminal/pole? Thanks.
The solenoid connections are: 12 gauge purple goes to "S" terminal and 20 gauge yellow goes to "R" terminal. If you have switched from points to HEI you don't need to hook up the yellow wire.
1 - 2 of 2 Posts
