Putting together a 350 using the Performer RPM package. I purchased much of the parts (crank, balancer, etc) from various mail order houses. How do I know if I am using the right timing tab with this balancer? I read that the balancer changed in about 69 or 70 so that it is a few (about 9?) degrees off from earlier models. The tab I have is a freebee from dad and is chrome and I suspect aftermarket. How do I ensure that my tab and balancer match?
Also, what are good initial and total timing settings for this setup? If these don't match up on my junkyard HEI, how do I adjust mechanical advance on a GM HEI. Thanks in advance. (PS - I've already done some searching and learned alot but couldn't find the answers to these questions)
measure the balancer. then get a tab. tell them what size you got. 6 1/4, 7 1/4, 8,. You also need to know what years all your parts came from because some motors are internaly balanced.
SS 327 65 malibu
SF CA
1965 SS
There is Nothing like An SS Made your way
65 SS Chevelle
All 350 are internally balanced so that isn't a concern. Look at your damper, if the timing mark is very close (2*) to the keyway, it is an early damper and your timing tab should work. If the stock timing mark is a ways away from the keyway (11 degs), it is a later damper and a aftermarket bolt on tab will be in the wrong position. In this case you could cut a new mark on your damper with a hacksaw, however you would need to locate TDC accurately either with a dial indicator (heads off) or a piston stop and degree wheel (heads on). Alternatly, you could get an early damper. Chevy still has them. With a high performance engine I suggest using an 8 inch damper
Pat Kelley
66 El Camino, daily driver
67 El Camino, STRIP/street
Pat's Page (CR Calculator, Utilites, car specs)
Are there any other ways to determine exact TDC with the heads on? I don't have a degree wheel or know how to use one, but I guess I could figure it out. Thanks BTW, when I had this engine kit balanced, they said they needed the torque plate and damper (I guess this means it is externally balanced?). Does this mean I can't use a different balancer and still have the engine balanced?
I've heard of companies wanting the damper and flexplate/flywheel. I think it is just to check that thay are neutral balanced. I've never heard of an externally balanced 350. If you are stroking and using a 400 crank then yes those are external balanced.
I don't know of a way to locate TDC with the heads on without using a degree wheel. Summit has one for $25-30 or so. It's not difficult, just time consuming.
Pat Kelley
Someone mentioned it a bit ago but use a piston stop (old plug modified) spin the engine BY HAND, clockwise, mark it, then CCW, mark it then split the difference. Got to be TDC.
Compared my old damper (which is definitely the old style) with the new and the new one looks as if the keyway and the TDC mark are a few more degrees off. So I guess I have a later damper.
Does this mean that all the cheepo timing tabs sold at the parts store are made for the early dampers? I find it odd that they don't say so on the package or in the ad. I guess I could get one of the adjustable tabs and move the zero over 8 or 9 degrees.
Thanks a lot
