1 - 10 of 10 Posts
I am about ready to put this engine together but want to be sure before I put the cam in. I already have the howards but thinking the comp might be more forgiving if the tune isn't spot on. Saying that, I am pretty good at tuning though. I have posted on this subject in the past but have narrowed the cams down and want to make sure before I go ahead and put this together.
Xtreme Energy 242/248 Hydraulic Roller Cam for Chevrolet Big Block 396-454 (compcams.com)
Howards Cams 120325-10 Howards Cams Retrofit Hydraulic Roller Camshafts | Summit Racing
THIS IS A STREET CAR
Here are the specs.
Big Block 427
10:1 compression <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< THIS IS MY CONCERN WITH 93 OCTANE
781 heads with 2.19-1.72 stainless valves, no porting but short turn was lightly worked and ports were cleaned up
Comp cams Pro magnum rocker arms
I will have custom pushrods made
Rotating assembly was balanced
Edelbrock RPM intake
750 carb
Distributor will be custom unit that is phased and tuned to my combo
Turbo 400 with custom stall
Ford 9" with 3.55 gears
255 / 60/ 15 tire
All wrapped in a 67 Camaro
Get a Gen6 cam and a retaining plate NO setting end play but still check it , I'm sure you can get it with the Howards cam, I'm no pro but read a whole bunch on the subject :) that should be a real fun Camaro...67 Camaro :cautious: my dad sold mine while I was at school when I was 15 :mad:
I have a similar 427 I have put together, same heads with mild porting but a 9.75:1 compression. Howards recommended a cam with 10* less intake and exhaust. I would think you would have no problems with the Howards cam you have with your slightly more compression.
Reactions: shovelrick
242 too much intake duration - Howards.
Use the howard since you already have it, I think it will work fine with 93 as long as the tune is close.
Agree, Run the Howard, I have a comp XR282HR-10, PN 11-432-8 same duration, same lobe sep, slightly less lift on my .030 over 454 w/ 10.25:1 pistons, ported iron oval port heads with 2.19/1.88-inch valves. the car is really streetable but still makes 530 hp & 580 ft lb of torque. on 91 octane.
Boldly procrastrinating
what they said, run the Howard.
Reactions: BTK
1 - 10 of 10 Posts
