1 - 12 of 12 Posts
I am considering going back to a mecahnical fuel pump (mainly because I am not good at fabrication, so my current electric fuel pump mounting location is not ideal). I have the correct fuel pump pushrod on the way from Straub Technologies (who I purchased my cam from). My question is would the Edelbrock 1721 or the Holley 12-327-11 fuel pump be better?? 383 small block, that is supposed to be around 500/500.
Now, if there is someone close to me who is good at fabrication and would be willing to help me get the eletric fuel pump moved to a better location, that would be awesome (I would not expect them to work for free). I do like having an electric pump, simply because I can prime the carburetor quickly if the car sits for a while, but this is the second time that the motor has quit working on the pump (it was rebuilt in 2013 - the original one only lasted about 4 years).
Let me know what your thoughts are. Thanks in advance.
P.S. If someone knows of a straight through electric fuel pump (i.e. cylinder shaped) that would work well in a carbureted application, I am open to suggestions there. All of them that I have seen put out a lot of pressure, which requires a regulator (and I don't know if the regular Holley regulators will work at 40 PSI and above).
Reactions: Timothy Dixon
Mechanical pumps work real good, however they need fed. Most times these cars have a 3/8" factory tubing with a lot of tight bends. What I did when I got a aluminum fuel cell with dual sumped fittings. I ran two 3/8" lines from the tank to a tee in the fuel pump. What a difference!!!! Once you get the big Quadrajet on big Chevys fed enough fuel they really turn on..
Also, its real important to run a return line off the tee, 1/4" tubing is perfect. Usually most tanks have a port at the top for the return line..
Go with Edelbrock think they still are Us made. Holley, carter etc are made in Korea.
I had a brand new Holley fuel pump on my brand new 496. It lasted approx 45 minutes before the diaphragm ruptured and was spraying fuel all over my headers. Couldn’t even return it. Had a thirty day guarantee. So I can’t say I recommend a Holley.
Carter 172 has been flawless so far. And when it flaws, its rebuildable.
Yes but its been discontinued for over 10 years. Carter has two 120 gph BB pumps but they are now made in Korea and looks just like the Holley casting. I have both an Us and one Korea. Suppose its same with sb pumps.
I have a 13 year old Korea Holley 170 gph that has worked perfect had another that didnt work only 3-4 psi.
Edelbrock still Us made or at least was untill recently. Has one Victor that works great with a clay Smith/enderle bypass valve.
I will always run a mechanical as I never really trust electrical. I liked the Carter 172 as well but when I couldn't find one I went to the Holley 12-327-20. Once I get over a certain GPH I always add a regulator. Had to many issues with "no regulator required" just to have the pump at 7.5-8.5 psi and blow past needle and seats. I like mine to sit at 6.0-6.5psi. You'd be fine with anything around 80GPH.
Just installed a belt driven on a friends and really liked it. A lot more money in the system though.
Mike
1 - 12 of 12 Posts
