This same post can be seen in the "Had a 283 laying around, So I started thinking!" I figured it would be better to make a new thread.
My dad's 66 chevelle has been sitting in the garage since 78, when he decided to rebuild the motor and fix the rusty trunk. But he never got time to work on it so it has been sitting there untill I decided I wanted to restore it. He is the original owner of it and everything is still stock.
(10 bolt-3.08 gears, 283, Saginaw 4 Speed) I was thinking of building a 355, modeled after a crate motor (companies tell you everything that is on them, so why not build the "same" motor myself for half the price). Although my dad always tells me that I should put the 283 back in it. He says it is faster than I think, and has more power than I will ever need to use on the street. Apperently he isn't the only one who thinks like this....
"Kids that have never driven a short stroke, high rpm SB motor just can't really know what it is like ta put your foot into it until you get scared.. He, He!! AND then shift..." (PDQ67)
I doubt that I will race the car. I might take it to the track a few times for fun but I don't think I will do it all the time. I want the car to be slow, but get to top speed in a hurry (was thinking 4.56 gears or maybe lower now that I'm reading this). After all you can't go that fast on todays roads anyway. I would rather just show off and race from red light to red light.
I hate all of those japped up cars that everybody my age thinks are so fast, and I want something to put them in their place. Which motor would be the best for what I want to do?
Would a 283 have enough torque with that high of a powerband to get the Chevelle moving, or is that where the really low gears come in at? I was also thinking of getting a TKO 5-speed which would probably be a good idea if I'm going to get 4.56 gears or lower. Will just any 283 rev to 7000rpms or does it have to have something special done to it to be able to rev like that? I don't really want to blow any of the original stuff apart, should I get a 12 bolt and use a different 283 block? Will the 10 bolt hold up with lower gears? Would it be better to look for a 302 block to build a motor? They have the same stroke as a 283, correct? How will something that revs that high be for drivablilty?
Any advice will be appreciated.
Thanks, Josh
Thanks, Josh
