1 - 20 of 25 Posts
hey guys, im looking for which will best fit my combo.turboed 496.. 1,000cfm
1.throtle body
2. multiport
3. TPI
4. EFI
which would work well in response to the motor and which is easiest to tune?, id like the look of the multi port... but damn they are exspenive... how well do the throtle bodies work? and what about buying a kit that doesnt include the manifold? could i save a few bucks on buying my own manifold then installing the kit onto it? thanks?
Discussion Starter · #2 ·
ok im looking at a holley omander 950 tbi kit. it has a 900 cfm flow rate. could i put in bigger jets to got it up too 1,000 cfm? also would i need to install fuel rails? im new to fuel injection....thanks
· In Memoriam
900CFM is a lot. that refers to air flow, not something associated with jets. jets meter fuel in carburetors, injection doesn't have jets, it has injectors. the rails will be installed on the manifold. look at the pics
To clear some terms up here, all of those are number 4, electronic fuel injection. TPI (tuned port injection) is a multiport system.
Fuel rails are only needed on a multiport system.
As for what one is the best, for boosted applications you would want the system that has the most capable ECM. The TBI or Projection applications are usually set up for ease of installation and tuning, therefore limited capabilities. Im not saying you couldnt use one of those, but a MPFI system with a wideband option would probably suit you better.
I would go the the bookstore or look on ebay for a book about aftermarket EFI systems.
I would look into MegaSquirt. Especially if you are looking for a learning experience/project. It is cheap and VERY capable, if you have the time.
http://www.msefi.com
Rob,
You have me confused, what part of "496" and "turbo" goes along with "cheap"? ;)
Most of the throttle bodies on EFI units flow around 1000 CFM under NA conditions. Put some boost to them and that number can increase.
As soon as you put a turbo into the mix you have increased the commitment level significantly. Things get a lot more serious and more expensive when you want to go that fast. And require a lot more knowledge. I recommend getting some reading material and or doing some surfing to learn more about how the EFI stuff works. This is about the only part of this that is cheap: buying books and reading. Beyond that can get expensive, especially if you either wind up with the wrong stuff or worse smoke an engine from mistuning.
yeah i know things arent cheap its just im tryign to learn all these new things to understand turbochargiong and the fuel system and it kinda gets overwhelming at times. im going tp look up some mpfi stuff to learn more and better understand. but thank you guys for the help.:thumbsup:
· In Memoriam
Thanks Doug. just the ticket.
For a top end system i Prefer AEM.
Midrange price concerned users always like Microtech. I used the Lt4 and LT10 with bot dist or separate coils. With dash controller you dont need a laptop for fine tuning. Really cheap. And very good.
Cheap system. Megasquirt. Or Vems. Vems is a much better system.
Rob,
Exactly.... Why a turbo Efi BBC? Just build a big 540 and be done with it.
You are looking at a min of 15-20k for what you want to do, especially if you don't know much about EFI/turbo's. I would suggest spending 8-10k on a 540 and throw a blast of 200 NOS on it. ;)
Why does anybody want a 540? its a starter motor ,)
A turbo motor will kick these little 540:is around like theyre were toys.
Blown cui will always be better ,)
My "starter motor" will have two hair dryers on it next year :D My goal is to be able to pull a Hyabusa or ZX-1400 from any speed on the freeway (within the aerodynamic limits of the car, of course) :thumbsup:
good god if you could pull a busa thats super fast! yeah i just have to have a blown bbc! i mean i hear they are a blast, exspensive yes but i hear once you go blown you dont go back.
I didn't say I would, rather that is the goal :) The busa's are fast, and the new ZX-14 Ninja is even faster. I've seen 1/4 times in the 9.20-9.30 range with a lightweight/experienced rider :eek:
1 - 20 of 25 Posts
