Hi all. I have done a lot of research trying to find out exactly what 396 I have. The ONLY numbers I can get off this engine are 3969854 and the build date of A 8 70. Guy I got it from says it was out of a 70 Chevelle. I know it could probably be 1 of 3 different HP ratings. I have checked every spot where a stamp or raised letters should be but they look like they were never stamped or cleaned off. The only other thing I come up with is that the 3 holes above the oil filter are all threaded and the middle one had a plug in it that I took out. I read that if this is 1/2 in threads then it might be the 375hp. What is the most accurate way to measure the threads ?
Chris
Chris
