I heard you can get a updated tko600 to hold up to 1000hp and shift much better. Anyone know where or how to get in touch with the company?
Okay, I will bite. What happened with to you with the standard Tremec case?Be sure they replace the case with something stronger than Tremec uses. Ask me how I know.![]()
How much hp do you plan to make and how will you use the car?I heard you can get a updated tko600 to hold up to 1000hp and shift much better. Anyone know where or how to get in touch with the company?
Yep, we`re just 15 minutes outside downtown Knoxville in Blount County. Stop by so we can chat about your project and show you the place.Jeff, great info. We do often get caught in the marketing traps :yes:.
Are you guys really just up the road in Tenn? I didn't realize that. I'm planning a coupe Fox body LSx project that may have TKO 600 written all over it based on your info
John
First trip to the dyno after installing the new motor from Mike, snapped off an ear and cracked the case (in another location) during 3 wot pulls. Sold the TKO 600 to a friend for parts and bought a G force.
The tko was an off the shelf unit. Not the beefed up version referred to here - but if they don't replace the case, too - it will continue to be the weak link, imo.
No way! Transmission install 101. Never use the ears to seat the input shaft in the pilot bearing. It was either a faulty casting or just too much tq. The motor makes 700 vs the 600 rating. It also cracked in a completely different location.Quick question when installing the trans did you get it to the bell surface or was it a little tough and you used the bolts to suck it up?
