where can I get a speedo reduction adapter?
1086 7
I just put in a 17 tooth driven gear and my speedometer still reads about 20 mph slow.
does anyone know where is the best place to get a reduction adapter(the one that fits between the tranny a cable).
thanx
Justin McIver
Sacramento CA
66-454-th350
1 - 8 of 8 Posts
As far as I know, those are dealer only items.
I went to all the local parts stores in my area and came up blank every time.
If I remember correctly, they are color coded for the different gear ratios
Lynn Robinson
Pacheco, Calif.
64 Malibu SS, 71 Camaro SS
"Just Hit the Ball and Touch em All"
Team Chevelle Member #246
I have two. I don't know where to get them retail but have found them on trucks.
The manufacturers names are S.S.W.I.P 1.3000 :1 and Hubbard .833:1 P/N 6477865. Might try a web search and get a line on them if not try Tomas Register at the Library.
Harley
69 461 El Camino Nitrous Model
69 Chevelle coupe
71 SS Camaro
75 L-82 Corvette
71 Gremlin X
Kerrville,Tx.
You can get several ratios from GM and any speedo shop that has been in business for a long time can make one up for you.
Tom Parsons
Check the speedo shops. In Chicago they will custom make one for your car for about $60. I brought the car in once so they could find out how much the speedo is off, and returned a few days later to have them pop it in. They could also send it to you, its a very easy job to intall.
1 - 8 of 8 Posts
