My engine is in the machine shop, and the machinist asked me what I wanted to do with the valvesprings - he said he would of course them. The springs are Manley 22441-16 and have 2.5 seasons of bracket racing in the mid-10's car in the signature, and some street driving.
I had a custom set of pistons made (with Wolfplace's help) that only have a .060 valve pocket on the intake and had .050 clearance above the piston face, or a total of .110 clearance. The heads had to be milled .015, so no clearance is down to .095 piston/valve. I went with the small valve pocket avoid burning the edges of the piston again if my tune goes lean. The valve springs won't have more than 10 lbs of boost to hold back. The valve springs were set at 150 lbs last time, but I don't know the installed height.
The cam is a Comp Cams SFT 11-405-5 with .605/.612 255/266, 114 and am using the identical grind again. I woiuld like to know if these valve springs should be changed just due to their age/use or if they check out alright I can save the $200 on a full rebuild which promises to go to about $3500 assembling it myself. I upgraded to series 2000 rod bolts, etc.
The rest of the motor is fresh - does it need another $200; I'm not looking so forward to picking it up at the machine shop right now but sometimes you can't cheap out on important parts.
