Finally cleaning out the garage and found all the old wheels that came with the car. The rally wheels i believe to be reproductions based on the other threads i have seen here. Just want to confirm, they are stamped K189 5 15 AZ meaning reproduction wheels made in 1989 right?
Another question is on the drag wheels. I can't find any manufacturer name markings after pressure washing and scrubbing dirt from various areas on the backside of the rim. The only markings are shown in the pics. Stamped C on the hub, 2667 on one of the spokes, and "gardena, calif " along with size, racing spec and max load on the outer rim. No markings on the front or anywhere else. Any idea on how else to ID these? Trying to get an idea as to what they are worth.
Could you take a close up of the front lug area and a larger photo of the face? It looks like it's either going to be a straight Chevy bolt pattern or will have a counterbore for an offset drilled washer.
Without a brand name on them they may be nearly impossible to identify. There were numerous companies making that style of wheel, and I think about half of them were based in that area. The larger brands typically put their name on it.
