I agree with Kirk. I said no to a few set of off the shelf wheel because i needed the usual backsapce that goes with 10 rear. where as a cheaper (read half the price) wheel would of fit if my rear end sit just right and the inner fenders were original.
measure, measure, measure again.
the sticky in wheel and tire forum will help alot also.
and the difference can be in tire size. the 295 of 1 brand can be the same as 305 in the other. that is what alot of people choose nitto as they tend to run on the smaller side. and this basically means that the sidewall is built a little different and the overrun from the where they measure the tread is shorter.
but
measure measure measure
and if you read around the net, some guys are running 315 on rears. but that an 11inch rim with coilovers as well and pro touring suspension with roto joints to reduce flex.
there is alot more to getting big tires under the rear if you want it measured down to the mm.
