1 - 10 of 10 Posts
350, .30 over (355) vortec heads about 375 hp to the flywheel, 373 gears stock trans. How should i launch the car? should i load the converter or slam it at an idle?
Hey Mitch; Welcome to T/C.
The guys are going to ask for alot more than you have posted.:yes:
They'll want to know:
Compression
Cam size
Heads used
Intake
Carb size
Stall speed
Tire size
Open differental, locker or spool
Which trans
What rear end
etc.
etc.
etc.
You think I'm kidding. :noway::thumbsup:
alright here we go:
355 sbc
10.5:1 comp
cam .480/.480 (havent had time for the cam swap yet)
vortec heads
RPM intake
carb is 625 demon road master
stall speed is stock :(
tires are 255 50 bf goodrich w/ about 25 psi for traction
8.5 posi w/ 373 gears
th350 trans
the car weighs around 3800 with me in it
street tires or dr's?
just go out and try it, but it seems loading the converter results in spin, so i would say slam it from idle.
mid to upper 13's also if you can hook. i think the converter and carb will hurt. put a 2800-3k in it, and watch you do 1.8 60's and high 12's.
aaron
Converter, converter, converter
1 - 10 of 10 Posts
