1 - 8 of 8 Posts
I have a .030 over 350. goiong to put a Eagle competition 383 stroker kit in it. 3.750 stroke, 5.700 rods, what's the cubic inches of the motor after this install ?? Also going with Dart alum heads 215cc intake runners / 64cc chambers. should be close to 11 to 1 comp. Dart alum single plane intake, 350 at, 3000 stall, 373 posi rear, cam solid mech tappet 255/265-504/504 What size & brand carb would you suggest , whats the smallest i can go and what's largest ? I want a hot street and sometimes strip, going on a 3300 lb car , Thanks, any other ideas, exhauts,distributor, etc ??
In Memoriam
those are big heads for a 383, be sure to have the right valve springs installed correctly for the cam. What's with that cam anyway? is it 255/[email protected] lift? if so, why only 504 lift? if it's advertised duration it's way too small, it will never let your engine get up to an RPM suitable for those heads.
THE 255/265 IS @ .050. WITH THAT IN MIND WILL IT BE ENOUGH ? WHAT WOULD YOU SUGGEST FOR HOT STREET, I ASKED THE TECH AT DOUG HERBERT AND THIS WAS HIS SUGGESTION, #CCR4, WHAT'S THE BIGGEST SIZE`INTAKE RUNNERS DO YOU THINK I SHOULD USE ? THANKS
Banned
I don`t think that cam is too big for a 11:1 383 but the lift is pretty low for the duration. With your heads flowing as good as they do, I would run 1.6 rockers to get the lift up or change cams. My buddy ran a similar motor and ran a Crower 00351 cam. It was something like 254/[email protected] .525/.543 106 LSA. Ran really good in a big old 62 chevy truck.
1 - 8 of 8 Posts
