A non A/C dash harness will have the connector for the blower speed switch along with the wiring and connector for the speed resistors and a wire, orange, from the speed switch to the bulkhead connector. The speed resistor connector is usually white and has yellow,orange and ltblue wires.
Also on a 70 heat only harness the top fuse on the right side of the fuse block will be marked as TCS only the A/C harness will be marked A/C TCS. This doesn't apply to the 71 harness, which will also work in a 70.
