Awhile back I had to change the oil pan seal on my 355 SB. Sitting at the bottom of my 7 quart pan was what appeared to be a brass colored washer. It was about the circumferance of the HEI distributor shaft and I figured that has to be where it came from. Low and behold, I put another 7,000 miles on the motor with that same dist. with no real probs. Now I want to change out my points dist. on the 402 with the HEI off the 355SB, but I'm wondering if thats a smart call concidering there might be a missing part to the puzzel. Also, I heard shoddy distributors can cause valve train failure and oil pressure problems. Any help whats-so-ever on this topic is greatly appreciated! :cool:
Administrator
If the washer you found was intact, not in 2 pieces, then it could have not came off of the distributer, at least not the one presently in the engine. Do you still have the washer? Can you post a photo of it?
If you really want a good distributer for your 402 contact Dave Ray in Whittier, CA he can build you one set up to match your engine specs and car.
I actually can't get a photo 'cause I just chucked it in the trash after I removed it
. But it was bronze, almost perfectly round but it had a spilt in it that made it like a "C". I also remember it having something like stress lines on the actuall washer it's self.... I just can't think of what it could be if not from the dist.
Administrator
That is strange, but unless you built the motor and no one else ever touched it you can't be sure of how it got into the engine.
