OK, is your piston down in the hole .002"? or you took .002" off your decks so they are close to say .023" down in the hole now??
Then I will run it through the ROSS Racing Pistons compression ratio calculator for you. Then run it through the BOOST Calculator site to get to a Eff/D CR. number for you...
BUT I have a feeling you are too high compressioned unless you have aluminum heads????
I just ran it using a .039" hg, a 55 cc chamber head, a -4.86 cc valve notch flat-top piston and a down in the hole of .023" and you are at 10.99 to be exact!
You need at least a 63 cc head, imho to make right at 10 to 1 CR which will give you a Eff./D. CR. of 8.04 at 600 feet elevation like me or thereabouts with that cam so you can still use decent pump gas..
(I used 272/210/286/224, 110/106 and guessed at the lifts of .450"/.480" to get the intake valve closing point of 62 number!!).....
Get back..
Check me guys!!
pdq67
