1964 300 or Malibu 4dr w a 6 /PG and would a 200R4 give up any milage gains to the PG? figuring a 3:something ratio.
With the low torque of a 6 cylinder the lower first gear of the 200R4 would help it. I would go with 3.70's.
Dave
The 6 cyl doesn't turn a lot of RPM or make a lot of horsepower but it has low RPM torque so should pull the overdrive well.
It probably came with a 3.08, possibly a 3.31.
Install the OD transmission and change the rear gear only if you need to.
Verle
