If the motor is stock or stock build with 10.25.comp pistons going from r44t to r44ts /newer extended tip design is a better choice for sure as Shurkey already stated.
I have used the newer design extended tip r44ts taperd seat design plugs (R44XLS for older heads with longer gasketed 13/16" design )for yrs in the 396 & 402 with 325-330-350-360hp along with 427 low perf(330hp?) and 390hp and 454-365hp motors all being the 10.25.1 comp motors with smaller domed slugs.
The r44t & r44ts are same exact heat range,on diff is non vs extended tip,that's it.
But the extended tip design plugs may be an issue with larger domed 11.0 comp pistons in the stock higher perf 396-375-425hp (65 vette ) ,427-425 & 435 hp & L88,and 454-ls6 450hp bbc's to name a few bbc's so keep that in mind. But if you look up the plug application for the hotter 11.0 comp bbc in a newer ac delco plug cat if it lists the extendedtip design as a plug to use for that application it should be ok,just treying to error on the safe side here with the larger domes hi perf 11.0 comp bbc's when it comes to the extended tip plugs.
But if your not sure of the pistons/comp then i would stay with the r44t plugs since they have been working well for you.
BTW,these older pt# plugs are a hard to come by ut i get them all the time from summit as they still get them from somewhere. I have not had as good as luck with the rapid fires in these 40 yr old design motors so dont waste you time with them for this application,for todays motors that they are designed for they are very good.
Scott
