Hi,I am close to firing my restored 69 L-78 Chevelle,all stock internals with 11 to 1 comp.What luck have you guys had with gas,do I need a additive or race gas? Let me know ,Thankyou
For startup and break in 93 would work just fine.
Just don't hammer it or drive it 900 miles in the interstate in July.
When you get it up, running and driving, and when you start to tune for good power and such, is when you want to to listen carefully, read plugs etc, to see if you need better gas.
Our L78 is just a stock build, 11-1 advertised compression. It seems to run just fine on 91-93 octane gas. We've put over 30K miles on it in the 10 1/2 years that we have owned the car. Now, if the engine has been machined for a true 11-1, you may just have problems with pump gas. Factory engines have been known to check out at 10-1 and even less.
Run 93 for breakin,then if you find later on it ping wit full adv curve just run this Kemco real lead booster sinces its likley a wk end use car only.
Here the contact info,chk out their website.
Scott
SHELF LIFE IS 18 MONTHS FOR THE KEMCO BOOSTER
Kemco Industries
1374 E. Main Street
Lehi, Utah 84043
Local Phone:*(801) 768-4408 | (801) 768-4409
Toll Free:*(877) 450-5877
Fax:* (801) 768-9150
Email:*[email protected]
