ugly. why did you want to know?
I wanted to know how much it weighed so I could figure out the anchor weight. Seriously....I didn't know what it is other than I thought it was Oldsmobile something or the other cause it's painted gold. It's available to me all I have to do is drag it away so I figured I would ask and I might get lucky and it might be worth something. Evidently not ...........
Its an olds motor all right...
Look on the heads- you should a Letter or a number cast into the right hand corner next to the head bolt. (ie A,B,C,D,E,F or 1 2 3 4 5)
Letters are for big block heads, numbers are small block heads. Can't tell just by looking at the bottom of the block weather or not its a big block as olds blocks were all the same dimentions.
