Looking to sell my 69 factory AC. Was working when I tore the car apart. Hoses are cut and need to be replaced. What is this worth? Basically going to sell the compressor (as a core) and all of the AC stuff in the firewall. thanks
well just my .02, but I have a set-up in classifeds, that I pull off a 69SS396 car back in the 70's as a unit, never even pull the lines apart on the condenser, with all the right brackets, no interest, what you have I'd say 200, jmo
Well just so you know the brackets alone will get between $400-$600 as long as you have every one of them and even the spacer with all the correct bolts and washers.
Also check the large bracket to see if it has a date code on it.:yes:
Like this.
Like this.
Thanks for the info, funny there was no interest on what I have, I pull it from a 69 SS, I bought back in 76, A beautiful original that was hit light in the rear, and total by the insurance company, a car I should have NEVER parted out, but back then, it was no big deal. I pull everything off the motor as a unit, never even seperated the lines from the condenser, and I sure all the correct bolts are in a coffee can, with the unit, I save everything. :) And it was working, when I drove the car home.
