1 - 9 of 9 Posts
i have a block with ventalation through the valve covers, one where the oil is poured in and one where there is a vacume line hooked up to a 1 inch spacer under my carb. what happens if i disconnect the vacume line and take out the spacer?
Nothing, as long as you're planning on putting a breather in the hole. I'd say keep it how it is now, that's a PVC system, and keeps the breathers from smoking... which makes a really nasty smell if you happen to use synthetic oil. Plus the spacer should improve top end power.
kenny
85 El Camino 355ci
350 turbo - 4.11's
best run so far 12.92
My Page
well im installing a nitrous plate and no studs are long enough to go through the 1 inch plate the half inch plate and the half inch base on the carb. glad to know it wont do anything thought thanks.
Make sure you have a baffle on that side... which I'm guessing you do.
kenny
85 El Camino 355ci
350 turbo - 4.11's
My Page
<BLOCKQUOTE>quote:</font><HR>Originally posted by justinhertel:
well im installing a nitrous plate and no studs are long enough to go through the 1 inch plate the half inch plate and the half inch base on the carb. glad to know it wont do anything thought thanks.<HR></BLOCKQUOTE>
Sounds like a stud about 3" long would do just fine. That would give you 1/2" engagement in the manifold and 1/2" left over at the top for a washer and nut.
67 Nova 3475# daily driver
10:1 406, 700R4, 224° Comp cam, RPM and a Q-jet - 11.76 @ 116
64 Chevelle Road Racer in the works
67 Nova Wagon under construction
65 Corvette Road Racer
I'd keep the spacer just in case you change your mind later, never know... sometime you might want to use it.
kenny
85 El Camino 355ci
350 turbo - 4.11's
My Page
1 - 9 of 9 Posts
