300 thats all wow seriously it said on the internet that the 350hp were more rare and i was thinking around $600 to $800
First, the 350 HP may be more rare, but its still not really "rare", there were THOUSANDS built... Secondly, the 325 HP and 350 HP used the SAME block, so there is NO rarity difference. The ONLY difference in the blocks, is the code (JC) stamped into it. But then again, there is also the VIN for the original car, so unless you have the car with a matching serial number, its just an ordinary 396... You can't get rid of the VIN without decking the block, which also will remove the "JC" stamp...
Then there are the Camaro/Nova/Impalas that also used the same block...
Now IF the buyer KNEW it was a good block, or there was a guarantee, then maybe you could get a bit more money...
