1 - 20 of 23 Posts
I build a street driven 66 chevelle and I have offer on two engines for about same price so I need suggestions to help me to buy the right one.
Here is the specs:
Engine 1
565 cui
Holley 1250
Victor jr intake
Brodix bb2 x heads
Eagle 4.25 crank
Eagle H rods with L-19 bolt
JE pistons
Comp mech roller 673 lift in and out ,dur 293 in and 301 out and lobe sep 110
Ultra pro magnum lifters
Msd distributor
milodon geardrive
Dart big m block part no:31273644
Engine 2
555 cui
Holley 1250
Dart intake
Brodix bb3 x cnc heads
Lunati kryptonite 4.25 crank
Eagle H rods with arp 2000 bolts
Venoli gas port pistons
Comp mech roller 800 lift in and out . dur 310 in and 330 out lobe sep 114
Comp one piece push rods
Comp . lifters
Msd distributor
milodon gear drive
GM Mark VI block 4.560 bore
Ok that was the specs any suggestions would be appreciated.
Thanks in forward
· In Memoriam
gas port pistons, 800 lift. not a street engine, even in this day and age where the definition of street engine has been stretched so far it barely means anything.
Thanks for replies !
Maybe combo one is the best for street use, but do you think about quality and strength
what combo give me most for the money ?
For example:
Dart big m vs GM mark VI
Brodix bb 2 vs. brodix bb 3
Eagle crank vs. Lunati kryptonite
I think a engine like this is more expensive here in Sweden , but how much can you pay in the USA for engines like this , both are new rebuilt with new parts ??
Any suggestions would be appreciated.
· In Memoriam
Dart, BB3, Lunati better, but are you willing the change the valve springs and pistons/rings every 50Km of driving? that's not very far.
I think the "GM MK IV" block is a Bow Tie block at that bore size. Which means it is a specialty block like the Dart. The Dart has more material, and is heavier.
Ok I think I´m gonna buy engine #1 I think thats the best for street driving.
What do you think about a vacuum pump is it something to spend money on ?
More suggestions about the engines would be very appreciated !
I hate gear drives on a street car.
How much compression do these things have? You don't see a lot of pump gas pistons with gas ports?
I wouldn't be scared of the Bowtie Block at all..they were good. But if I had choices I'd take #1 with the heads from #2 and a different cam.
And does #1 have an adapter to put a Dominator on the Vic Jr intake?
And no gear drive either.
JIM
Discussion Starter · #20 ·
Hello again
Yesterday I test the car with engine #2 (555) is in a fullsteel le mans -72 and without gas It runs 1/8 mile 6.40 and 104 mph and with 225 hp nitrous it runs 6.04 and 112 mph but the transmission (th 400 ) couldn´t handle the power.
Ok that gives me some headache what engine I gonna buy ,the engine #2 have about 12 in compression and runs on pumpgas (in Sweden)
Suggestions please !
1 - 20 of 23 Posts
