1 - 8 of 8 Posts
the alto red clutches in my direct drum are burnt up as well as the outer seal. i have read some post on here about this problem and i want to know hat is best to put back in, add more alto reds..... or try the borg worner waffle stlye. its a 400 with an art carr transbrake and a 300/157 low gear set. its in a 69 chevelle with about 550/600 horse bbc and 300 shot of giggle juice.:confused::confused:. i plan on adding spiro locks and a case saver what else should i do???
G
Factory GM Borg Warner Hi energy frictions from a 4L80-E. Sounds like you had too much clearance and caused a seal to fail, the reds also work well but aren't necessary.
G
.100" is too much and probably the cause ofyour failure, piston may have overtraveled and busted the seal.
.010" per friction is a good rule of thumb for that drum. 5 frictions = .045-.055" clearance.
how many full thickness clutches will the direct drum hold without machine work, this one is actually from a 4l80
1 - 8 of 8 Posts
