Put new 2 ga pos and neg batt cables on. When I turn the ignition on my fan nor fuel pump doesn't work. But if I disconnect small wire from starter and turn ignition on they work. Pos cable did not have small pigtail wire for fusible link. I connected link from junction box directly to pos cable terminal(think this is the problem). Should I have crimped normal wire to link then connected normal wire to battery?
What color is the wire you are disconnecting from the starter to make things work again? What is the “normal” wire you are referring to & what year /make car do you have?
1969 ss396. It has an aftermarket starter. It has (1) 10 or 8 ga red wire connected to the starter, but had a blue colored wire soldered to the red wire before the starter. Normal was referring to a regular 10 ga wire. Has optima yellow top battery. Thanks
