I just got my engine back from the dyno operator yesterday. After we loaded it on the truck, I noticed a piece of red tape over the timing cover cam button adjustment screw. He said that when he took the water pump off, the adjustment screw fell out and was stripped.
Once home, the first thing I did was turn the engine over by hand to set the engine to TDC. It was very hard to turn and made a horrible squealing sound. I immediately pulled off the access cover to the Cloyes quick adjust timing cover to inspect. The cam button was crushed and in pieces. I can see 4 bolt marks/ gouges on the front of the timing cover where obviously the dyno operator, when he put on the his water pump on my engine, did not notice that the water pump bolts hit the timing cover when he tightened down on the water pump. This obviously crushed the cam button. Obviously, it was run/ dynoed that way.
With the pieces removed, she turns easier and most of the squealing sound when I rotate the engine is gone.. but still there a hint of the strange sound at one point in the rotation.
I am wondering what kind of damage this may have done to the engine.
thanks,
mike
thanks,
mike
