=I will take the block to install new cam bearings and need some help with the type of bearing needed went using a solid roller billet cam
Clevitte 77 or Dura Bond CH 12 or use the CHP12 or 12T ?
x2=
chp12 will be fine but i like the 12t
also not a bad idea to add a second hole at about 3-3:30 & put a groove on the backside of the bearing between the two holes for added lubrication
you can add a groove all the way around if you have access to a lathe or you can just use a dremel with a carbide tip to groove from one hole to the other
make it about 20 thou deep
don't forget to deburr the hole on the cam side of the bearing if you add one
.020 not .002Mike , Carl , I will try to get the CHP 12T build the hole at 3-3:30 and groove them .0020 deep, and how wide ?, the side of the holes?
Thanks Chris for the special news :thumbsup:.
Do not sand blast (or glass bead) the tops of the pistons. If anything you would be better off to polish the piston tops. The polished surfaces (piston crown and combustion chamber) will help contain heat during the power stroke and let it escape to the atmosphere during the exhaust stroke, and thereafter. (Thereafter means that the heat of the exhaust gas "plug" will travel quicker through the header primary tube and help develop the negative pressure pulse that will help evacuate the next exhaust stroke during a very short, but important, RPM range)THANKS Mike for the help ,you allways teach us how to make our motors live faster and longer :thumbsup:.
It is a good thing to sanblast the top of a new piston set ? ,one of the employes of the shop told me they can do this and will help burn the fuel mix ,![]()
Doing some searching for SR install coming up on new build. Just want to clarify that the clock position you are stating is 12 o'clock being lifter side and 6 o'clock being main saddle side when viewed from the front of block? This makes sense to me but that doesn't always mean I'm right.=
CHP12 will be fine but I like the 12T
Also not a bad idea to add a second hole at about 3-3:30 & put a groove on the backside of the bearing between the two holes for added lubrication
You can add a groove all the way around if you have access to a lathe or you can just use a dremel with a carbide tip to groove from one hole to the other
Make it about 20 thou deep
Don't forget to deburr the hole on the cam side of the bearing if you add one
Tim,yes, noon is up, 6 is down. Down is bad.
Hi Jeff,Doing some searching for SR install coming up on new build. Just want to clarify that the clock position you are stating is 12 o'clock being lifter side and 6 o'clock being main saddle side when viewed from the front of block? This makes sense to me but that doesn't always mean I'm right.
Thanks, Jeff
No valves,, I can fix that ,,,,Thanks Carl! Thanks Mike! Not that I have any valves that can dance yet.
Quick question, I have been searching and have not found a part number or length of ARP bolt to use with the AFR's on the four bottom ones?? I already have the ARP's from my 781's, just need the bottom four.
Thanks, Jeff
