*raises hand*
I am sure this has been addressed before and is probably a simple fix. I would like to know what alternator will fit my 72 chevelle stock 350ci brackets. If I have to change the wiring it for me is no problem, just need to know what car (alternator) to ask for.
I run a car audio shop and (of course) got a lot of draw on mine. I swapped to the (SI? 63? amp) alt. and I still have problems keeping a charge up on it. I've heard of the conversion to a "cs" alt. and it intrigues me. I am looking for something around 90-110 amps with (hopefully) around 20-30 at idle (my engine wont idle less than 800-900, big cam). What position should the mounting tabs be? Any tips/tricks would be greatly appreciated.
Bill
Go to www.madelectrical.com and read the tech articles on the "new system" and the 10si and 12si alternators, I just did this on my `70 and have more power to all accessories than ever, and headlights you wouldnt believe. I ordred a power-master alternator from summit, its a 100 amp that can be wired either way,(i.e. three wire, or one wire). If you go this way YOU ARE GONA LIKE IT.....
Discussion Starter #4
I am not particular on which one to use. I havent bought anything yet, so I am totally open to suggestions.
John_Muha,
That 94 amp should do the trick. Do you by chance know how much (at idle) this thing puts out? I drive around town a lot, and I hate the look of my headlights getting dim when running my heater and radio. Also, is this a direct bolt-on since I have already up'd the alt. once?
I used your tech article and did the first one that bypassed the external regulator. This helped a bunch, but I need about 20-40% more than that.
edit: Oh yeah, if the above will work for me what make, model, and year of vehicle to ask my local parts guy for?
Dont worry about the world ending today, its already tomorrow in Australia...Charles M. Schulz
[This message has been edited by da_bull (edited 10-21-2002).]
I think the 72 is clocked at 3 o'clock but too late to out and look. Take a look at yours. The MAD link should tell you the make and model to ask for.
The tech ref article isn't mine but the work of Wes Vann.
