Whats the best way to weld or mig whatever exhaust pipe? I seen a guy working a torch and a piece of wire melting it. Whats that about?
That's how I've done it for 57 years (the first couple of years, learning with a big cutting tip at the junkyard) but I'm beginning to get the hang of doing it with my Mig Welder with Argon/CO 2 now, just not very good at it yet."torch and a piece of wire melting it. "
That is conventional oxy-acetylene welding. Very traditional.
Disconect the battery !!! Done it more times than I can count with no worrys. 40lbs oxy, 7 lbs act. It will melt !!!I can't use a wire welder on a car - might mess up a computer or something-This is the reason why I went to this Melting rod way. I bought the rods today-they came copper coated-not sure about that yet. How much pressure should my torches have? Can't seem to pull a puddle to good. wants to burn thru.
Gas welding takes practice. Get some scrap on the bench and learn how before burning up your new pipes. Practice, LOTS of practice. Done correctly it can look like TIG. Set the regulators to provide a good full flame, then turn down (using knobs on torch handle) till there is barely any sound from the tip while burning. Good blue flame about 3/8 to 1/2 inch. Should be close for exhaust tubing.I can't use a wire welder on a car - might mess up a computer or something-This is the reason why I went to this Melting rod way. I bought the rods today-they came copper coated-not sure about that yet. How much pressure should my torches have? Can't seem to pull a puddle to good. wants to burn thru.
Just a little FYI, my shop is not just a general auto repair shop, I am also a full service exhaust shop. I have never ever ever never had an issue of electronics damage in the 8 years I have been open. Truly an old wives tale if wives talked about exhaust.I can't use a wire welder on a car - might mess up a computer or something-This is the reason why I went to this Melting rod way. I bought the rods today-they came copper coated-not sure about that yet. How much pressure should my torches have? Can't seem to pull a puddle to good. wants to burn thru.
