I have the same problem. I tried every combo of fittings (45*, 90*, straight) and nothing worked. I ended up buying an "S" hose form napa and cut it to fit, but it still looks like crap and I'm not sure it's going to hold. Someone told me it's the location of the hole in the water pump that's the problem, not the manifold. Don't know if that's true?Is it O.K. to plug the bypass hose on a BBC? The hose that goes from the front of the intake to the top of the water pump. I have a RPM Airgap and the hose is kinked.
:yes: Works on mine.Yes, I plugged mine. Looks nicer also. Drill a couple small holes in the T-stat plate and you fill be fine.
