The other day I ran my gas tank very low, then the engine started to run very rough. After pulling off the top of the 2v Rochester, I found sediment and water in the float bowl. I had the carb off the car a few months ago and found sediment but no water.
I blew it out, adjusted the float level and installed a new in-line filter and still I'm finding sediment and now water in the bowl. I realize that running the tank down so low probably brought in junk that's sitting at the bottom, but shouldn't the in-line filter prevent this from reaching the carb?
Is their any way to get the water that's probably in the tank out w/o removing the tank from the car?
Thanks for your help,
Rich
