Finally have everything rounded up to screw together my first big block - the last piece of the puzzle was a 'girlie' cam from CStraub :hurray:. Here is a list of my junk, including the head flow #'s:
GM 2 bolt 454 block, +.060" (a '78 model GMC 3/4 ton truck block)
GM cast crank, ARP studs
3/8" truck rods, ARP wavelocs
SRP forged pistons, 23cc small dome .005" in the hole
Mahle rings, Melling hv pump
Edelbrock Marine RPM Oval ports (mild port and bowl blend), 2.25"/1.89" valves, 290cc runners, head surfaced cleaned up, chambers cc'd at 109, ARP head bolts, Fel Pro .039" gasket
Crower 68363 springs (194#/560#)
Cloyes hex-a-just timing set
Morel lifters, c straub hyd roller cam
Crane aluminum roller rockers
Eddy RPM air gap, port matched, 1" phenolic open spacer
Holley 870sa carb (I know most of you hate these)
Hedman Elite 1 3/4 long tube headers
I don't have a distributor yet, was thinking of using a Davis HEI, would like opinions on this, or any other setup to fire this thing off.
Compression will be right about 10.8:1, cam specs are 245/248 @ .050", 301/306 @ .006", .646/.603 lift, 107/101
Head #'s good/bad intake, exhaust with 2"x6" pipe
.2 159.5 152 136
.3 224 217 167
.4 276 270 194
.5 314.5 281 222
.6 331 289 246
.7 320 295 264
Flowed on a Superflow 1020 at 28"
I hope to have it all together and dyno'd sometime in April. I'd like to hear opinions and horsepower/torque estimates!
.2 159.5 152 136
.3 224 217 167
.4 276 270 194
.5 314.5 281 222
.6 331 289 246
.7 320 295 264
