the worst part is usually the "dog leg" behind the rear door. that all needs to me fabricated. you can use a 68-69 4-door parts car as a donor for the dog leg. also the 68-69 2 door wheel lip section i believe is the same if you need to fix a wagon wheel lip. i have put elky lower quarter patch pannels on wagons, but not the full lower elky quarter. i do have some i bought to do that , just havent gotton to it yet.
I just put a goodmark elky on my 72 wagon. Lot of work.. gas door needs covered, the dog leg is different, also the curveature of the 1/4 is different. I cut mine just below the body curve on panel an it's different than the wagon. The dog leg curve/wheel well is different. Alot of cutting and reshaping to get the correct curve around the dog leg/wheel well. I had the help of Erick Elkin (Body shop forum) doing this and still was alot. The wheel lip sticks out alittle more than the wagon well as well. But, try finding a wagon 1/4....
Rick
