Mark,
Have you ever found power adding a stud girdle to a bbc engine with a roller cam and iron heads?
what kinda spring pressures are you working with??Mark,
What’s in the heads? I couldn’t control my steel head parts at high rpm and that was a .725 roller. I went to 2.25/1.94 11/32 stem valves with k-motion 1000 springs with titanium retainers to finally control it. 3/8” stem valves and steel retainers just wouldn’t do it. After that I ran 1000h springs for several years and then went to Manley Nextek springs. I was over 300 and 800 with the last springs.240 seat 600 nose pressure.
I know what they do and what they can help with.
But that wasn’t the question.
I’d like to raise the rpm over 7400 which it starts popping at and utilize my looser converter and higher gear.
I never back to back tested it.Mark,
Ok thank youI never back to back tested it.
It is closed chamber?240 seat 600 nose pressure.
YesIt is closed chamber?
Ya know I never had closed chambers carry power, although SS 325 HP 396 get them to turn 8800 RPM in the lights, have you opened up the area between the intake valve and the spark plug?
Sorry I don't Foxwell did a set of 063s and the chambers looked good, ask him to post it up.Do you have a pic to share possibly?
