im gonna hook up all my gauges tomorrow oil temp and voltmeter.it says to hook the voltmeter to a switched source.I was palnning on using the wiper fuse to hook it up.will this work?? also the white lettering on my 68 malibu fuse box is worn off.is this right
left side:
blank right side:
20A clock 20A wiper
20A tail lights 20A heater/ac
20A stop lights 10A radio
4A instrument light 20Adirectionals
10A gauges
[This message has been edited by mykes68 (edited 04-03-2002).]
You can connect the volt gauge to the IGN terminalon the fuse block. It's just above the short INST LPS fuse. Connected there the volt meter will read only when the ignition switch is in the on position.
[This message has been edited by Elree Colby (edited 04-03-2002).]
