Hey guys...
Checked my charging system account 11.98 VDC at battery, engine idling, no lights/accesories on. Checked voltage readings and found this...
At extenal voltage regulator...
Key OFF / removed from ignition - Regulator plug removed - 12.8 VDC at battery
F (blue) = 0
2 (white) = 5.38 VDC
3 (red) = 12.77 VDC
4 (brown) = .008 VDC
Key ON / engine not running - Regulator plug removed - 12.4 VDC at battery
F = .004 VDC
2 = 5.32 VDC
3 = 12.23 VDC
4 = 10.73 VDC
4 brown dissapates voltage, after key is OFF / removed, slowly at a rate of .3 to .5 volts per second until it reaches .008 VDC.
At this point, I STOPPED and removed both battery cable connections and ohmed the blue & white wires between the altenator and regulator (both had 1 ohm resistance). Waiting for wiring diagram to arrive prior to poking around any further with my multimeter.
It's a 1969 SS, 396 auto, factory non-A/C car. Factory tach & gauges. Bought the car and parked it over the winter so this is the first time I really poked around under the hood.
Other known problems...
Ammeter AND Oil Pressure gauges inoperative.
Ammeter needle stays at first line towards Charge (off center) at ALL times (key OFF, ON, engine running).
Oil pressure needle stays half way between center and HIGH at ALL times (key OFF, ON, engine running).
There are only two wires at junction block behind battery, both heavy gauge Red.
The Field and Relay plug at the alternator was cut & spliced, the plug has Light Grey and Dark Grey wires spliced into two black wires. Followed the two black wires and the BATTERY red wire behind left side radiator, that harness exits behind the battery as BATTERY red, Relay white, and Field blue (splice somewhere along radiator) Battery red goes to J-block and meets ONLY heavy red from battery. Blue F and white R u-turn back to voltage regulator.
Regulator case has a good ground at core support.
Engine was cranking slow, but starting, which caused me to check charging / cranking system in the first place.
Heater blower fan inoperative on HIGH, turns slowly at other positions.
No other hokey cut/splice wiring apparent under hood.
I searched this forum and haven't seen anyone else with these voltage readings at their regulator plug. The readings immediately caused concern, especially the 2 white (5.32) and 4 brown (10.73) with key ON engine not running. The wiring schematics won't be here till the end of the week, so I was wondering if anyone can start me looking in the right direction. My last car, a 71, had newer parts (internal regulator, HEI, aftermarket gauges/voltmeter) so I'm not familiar with a 69's electrical workings yet. I'll check back during the week and post any results...thanks in advance guys...ya'll have been ALOT of help since I joined the Team...Rob
F (blue) = 0
3 (red) = 12.77 VDC
F = .004 VDC
2 = 5.32 VDC
3 = 12.23 VDC
4 = 10.73 VDC
