I did a search and could not come up with an answer to this...
On a Chevelle with an externally regulated alternator, where the voltage regulator is mounted to the core support behind the headlights, should the regulator be directly bolted/screwed to the core support, or should the rubber shrouded mounts be used? (I believe they are called well nuts).
Mine is mounted directly to the core support with sheet metal screws and all is working well. Is this a problem waiting to happen? What is the skinny on well nuts?
Thanks in advance for the help and the education...
Patrick
Patrick
