where is the best place to hook up the positive lead of an aftermarket volt meter. do i want to use the fuse panel on a circut that is hot when the ignition is on, or do i want to tap the voltage regulator on the radiator support. (1968 chevelle)
The best place is always debateable. The purpose of a voltmeter is to show whats happening (voltage) at the battery. IMO, the best place is right to the battery, using a relay as the switch.where is the best place to hook up the positive lead of an aftermarket volt meter. do i want to use the fuse panel on a circut that is hot when the ignition is on, or do i want to tap the voltage regulator on the radiator support. (1968 chevelle)
