1 - 2 of 2 Posts
I have a '67 Chevelle non vinyl top two door hardtop. Has anybody installed a vinyl top on a non vinyl top car. If so what will I need as far as trim pieces, any holes drilled into body and how do I prep the roof before installion.
All of the trim and clips are available, If your roof is already painted and no Rust you are good to go, Just use grease and wax remover to prep the surface, Remove the front and rear window moldings.
1 - 2 of 2 Posts
