I can't get the vent window out of the door of my 65 El Camino. I was able to get it out when the main window was out of it, but I can't figure it out with the glass in.
Thanks in advance.
Dale P.
Team Chevelle Member# 423
65 El Camino
72 Monte Carlo
"..you did you take the washer off, right?"
Administrator
Have you removed the bolts holding the rear window track in place and slid the glass back as far as it would go? If so it should lift out of the door. Philip
Phillip, Thanks a million! That did the trick. I knew it was something simple.s
Dale P.
65 El Camino
72 Monte Carlo
