Does anyone know where to get the piece of U shaped rubber that goes on the vent window glass before it slides into the frame? I've looked all over and no one seams to have it. Not having this piece is holding me up from putting the doors together for an LS6 El Camino I'm assembling.
they tell me to go to your local auto glass place and ask for 'glass setting tape', I did and got enough to do both vent windows for $5. If you're able to salvage a piece of the old, take it with you so they give you the right thickness... good luck!
What did you do, just fill the channel with a small bead then trim off whatever squeezed out with a razor blade?
Yes - He left a new tip for the cartridge and I cut it for a small opening. He warned not to mess with any excess until it had cured...as you guessed trim it flush with a razor blade. Used sparingly you should not have that much ooze to deal with.
